Troybilt rear engine rider has no spark
Dave9354
I have a troybilt rear engine rider that turns over but no spark at the plug. Any ideas as what to look for? Thanks guys!
Scrubcadet10
Moderator
Staff member
remove the engine cover, (trust me, you see it, it's what covers the entire top of the engine, also known as a blower housing) locate the ignition coil by following the plug wire to it... there should be a small kill wire hooked to that coil. remove it and try to start the mower, if it starts, the kill wire is shorted to ground or there is an issue with the keyswitch grounding the kill wire. IF it does not spark with the wire unplugged, bad coil.
assuming it has a new spark plug.
I'm going with dirty cooling fins for 100.
Dave9354
Replaced the coil and it fired right up! Thanks for your help!
