Troy-Built Super Bronco CRT Tiller - tines not counter rotating
tankmcnamara
  • / Troy-Built Super Bronco CRT Tiller - tines not counter rotating
Bought this tiller used. It was like new. However I have noticed that it is supposed to offer counter rotating tines. Tt does not. They rotate same direction as the tires, therefore, it does not till very deep. Anyone know how to fix this. Belts on wrong or what?
If tires rotate forward then belt is on correctly. Only things that would make tines rotate wrong direction would be incorrect gears inside the tranny. So either the tiller is not a CRT, somebody has changed something inside the tranny to make the tines turn the wrong direction. Or the tines are turning counter rotate, but doesn't appear to be because the tines on on the wrong side of the tiller.
