Troy-Bilt TB32EC Weed wacker not starting
Amituofo
Hi Expert,
My Troy-Bilt TB32EC Weed Wacker won't start. The whole carburetor assembly works on another weed wacker. I also replaced the spark plug.
This trimmer has been making squeaky sounds when it was working.
What should I check next?
Appreciate any help you can provide.
Did you check for spark with a known good plug. After that then it maybe time to borrow a compression gauge and check compression. Below 90 toss in the trash.
Amituofo
The spark plug works in another trimmer. I presume it's good.
I think it's something to do with the engine...
