Export thread
Troy Bilt Storm 2860 wont start
#1
D
DB14867
Hello all,
I bought a new Troy Bilt Storm 2860 late last spring and used it a couple of times. I use ethanol free gas and treat it. I left the fuel in it since it was treated (bad move). Yesterday I tried to start it and no go. I finally got the shroud off and got some starting fluid into the carb and it started right up and ran for a few seconds. The tube to the primer bulbs is OK, so no air leaks there.
How much of a job it it to get the carb off and clean it?
Does anyone know where you can find a manual on the engine etc?
Thanks in advance.
Dave
#2
Boudreaux In Eunice La.
What engine do you have and a Model number is needed for us to tell you anything....
I can tell you a carb job is an easy one ...........
#3
D
DB14867
it's the 243 cc engine, not sure the model, where can I find it on the engine?
Is it as easy as just getting it apart and using some carb cleaner since it is relatively new?
Thanks
Dave
#4
Thanks
Dave
we getting closer .......... Is it a briggs engine ??
#5
I googled your info and it's looks you got a Briggs on a snow thrower....
The model will be on the shiny valve cover ...........
#6
D
DB14867
Here are some pics.
I have read that the engine is actually a Chinese brand called Powermore, and is supposedly very similar to a Honda engine and made for MTD (TroyBilt). TroyBilt Snowblower Valve Cover.jpgTroyBilt Snowblower Carb.jpgTroyBilt Engine Serial Num.jpg
Thanks
Dave
#7
Ok now we know ..... Yes the carb is easy .... We don't use snow stuff down here but this past winter we almost needed them.... 3 snows a year is unheard of.... Maybe 1 every 15 years and it lasts only a day on the ground......
Back to the carb just take it off and take it apart....... Clean well with carb spray.... I don't know which carb you have but the bowl nut might be a jet also.... It will have a hole in the top of it and 2 on the sides if it is a jet......
Let us know mon Ami ~!~!
