Troy Bilt LTX-1842 Systems Indicator Monitor
jrr0863
Hello,
I have a Troy Bilt LTX-1842 lawn tractor that is equipped with a Systems Indicator Monitor. The oil pressure warning light is not working. I received some advice that it might be a bad oil pressure switch on the Briggs and Stratton engine. I contacted B&S and to my surprise they said that particular engine is not equipped with an oil pressure switch. They referred me back to Troy Bilt. So my question is how does the oil pressure warning light work if there is no oil pressure switch and how can I get the low oil pressure warning light to work?
