Trouble after replacing parts in drivetrain!
computersmith
After recent drivetrain work 3011X6s won't roll. Seems to mow OK, makes grinding going into reverse. Tires spin opposite directions when turning one tire on stand and the same direction when turning both wheels. when on ground
rolls really hard if at all. Any advice on what to look for?
What work did you have done on the drive train? Unless we know what was done on the unit, it will be tough to help you out. Did you open up the gear case? Did you replace any parts? If you had it apart, did you have a diagram handy when you reassembled it? The techs on this forum are good, but we are not standing next to you seeing what you see and hearing what you hear. Help us help you.
