Transaxle-RH for BobCat 942407J
DougSocialCircle
I have a BobCat FastCat Pro-FX730V KAW W/61 SIDE DISCHARGE (942407J), bought 2014, 840 hours. The Right-Hand Transaxle is making a horrible chattering noise. The shop tells me I will need to replace the Transaxle-RH (part # 4163772). This shop cannot find the part. I have tried several other shops and no one can find the part. Can any one help me find this part? Thank you.
Phone Mulligans transmissions .
If you look closely at the drive you should see the makers ID tag which has the make , model & serial number for the transmission.
