Cleaned all the orifices in the old carb with wire and carb cleaner. Sprayed dry and installed back on the tractor. Tractor won't even turn over.
I bought the new carb at a stand alone mower shop.
Mowing with a small hand mower reeks!
Again, I appreciate all your help.
If by "turning over" you mean rotate, that had nothing to do with the carb.
Try popping it back on and give the engine a little whiff of starter fluid or a dash of fuel down the carb throat to help it get going without draining the battery.
Because of the auto compression release, a mower that is turning over too slow will not start as all of the fuel escapes during decompression.
