Toro zero turn solenoid help
sacalait59
Have a zero turn toro with 16 hp briggs and stratton. Lost manual and need to replace solenoid, anyone know the part number? It is a 4 pole solenoid. Thanks
earthworm
Have a zero turn Toro with 16 hp Briggs and stratton. Lost manual and need to replace solenoid, anyone know the part number? It is a 4 pole solenoid. Thanks
Read your data plate, these are hard to lose, with this info, you may be able to secure a manual.
Or you can take the solenoid to a good store (good luck here!) and match it, without knowing any numbers.
Most good small engine repair shops should have one in stock, or can order it for you. There are about three different styles so just take it in and they will match it.
