TORO WHEELHORSE 71199
cedric
I HAVE A TORO WHEEL HORSE WALK THROUGH RIDER AND EVERY TIME I START IT AND RELEASE THE CLUTCH ,IT STALLS. AM HOPING FOR SOME FEEDBACK ON THIS PROBLEM. THANK YOU FOR SOMEONES TIME.
One of the safety switches is faulty or the wiring between then is faulty.
The mower thinks there is no on on the mower so shuts down when the brake is relesed.
You are looking at the seat switch in particular.
Be careful as it is a grounding circuit and sending 12V down the wrong wire will fry the ignition module.
