I have a late 80's 44" Toro walkbehind. Put new coil, igniter, and plug-still no spark. Took apart the engine connector that runs to the ignition switch and runs like a champ. Plug the connector back in, the engine dies. Tried ti use a regular toggle to rule out switch but did not work. I have also replace the pto switch. Any insight on the problem?
