Skippydiesel
My neighbour has asked me to bring his very old Twister back to life. This I have done.
Powered by;
I cant get the the engine to, no load, idle at the required 1025 +/_50 RPM. If I go that low it just stalls on me.
NOTE: RPM to go that low to take the "load"/tension of the belt drive so that the transaxle can be engaged without a large jerk and more importantly, so that the transaxle can be disengaged. At present, have to turn engine off, to remove load, then Forward / Neutral / Reverse can be disengaged.
Please advise how to improve low speed idle????
Some history;
Powered by;
- B & S V Twin, Horizontal Shaft, Model: 305447, Type: 0116-B1, Code:11030711 (made in Japan)
Some history;
- Delivered to me in very poor condition.
- Has been worked on, before me, by a complete idiot - lots of signs
- Almost no, very black oil, showing on dip stick
- Air filter almost completely blocked
- Starter motor not operating
- Battery charging circuit not connected - owner just charged up battery when engine not starting
- Very dirty - lots of chaff in cooling system
- Missing cowling air inlet grill
- Lots more
- Engine will fast idle for a significant time (3 minutes) then die
- Tends to die when "gear" selected. When restarted runs normally.
- Good high rpm performance.
- Signs of high oil consumption - exhaust a bit smoky
- Took top of carby - all appeared normal (may be I should have done a full strip & clean?)
- New NGK BCPR6ES spark plugs
- Armature airgaps very wide & uneven (looked like done by eye) - returned to 0.25mm
- Intake/Exhaust Valve Clarence's (also very wide) - returned to 0.13mm
- Oil & filter change
- Air & fuel filter replaced
- New starter motor installed
- Cowling & fly wheel removed to facilitate removal of heavy chaff/dust contamination
- Fixed broken charge wire
- Removed & flushed fuel tank
- Replaced all fuel hose's
- Replaced air inlet grill
