Toro Timecutter ZX Oil leak
Wraunch
0F31C941-3D7D-49AE-BCA6-2B33B70824A7.jpg8B829697-9EF5-4ED5-B2BC-D78D31D226A4.jpgEAB5E6E6-8A8C-410E-BCEB-7BD7281B6680.jpg
Picked up new to me mower, got it home and it was leaking oil. Guy took it back and replaced valve cover gasket. Now I still have a small leak under the motor. Thoughts?
MowLife
Hard to tell by picture if it’s still your valve cover leaking or somewhere else. I would pull the cover off and clean up well and use RTV sealant with the gasket. Check for valve lash adjustment while you have the cover off.
7394
Ditto......
