Toro Timecutter 18-44ZX turning problem
IdahoKevin
Hi everyone. I have a Toro timecutter 18-44ZX that is having some steering issues. So far I haven't found any help online concerning my exact problem. My yard has a small hillside that if I am going down the hill and try to turn to the right, it will not turn. If I go down the same hill and turn left, it will react as expected. Is this something that can be adjusted or do I have a mechanical problem? When the mower is operated on level ground the right side lever must also be just slightly more forward than the left side lever in able to go straight. Any help would be appreciated. BTW, I am not a real genius about mechanic work. :confused2
https://www.toro.com/en/parts/partdetails/?id=28013
Click on manuals, then service manual, then second service manual 492-4736, then section 5 page 3. If you don't feel comfortable working on steering, I would take to reputable Toro dealer. Tires, brakes, & steering are the three most important parts when it comes to Safety.
I'll share a short but true story: After 4 yrs. of U.S.A.F. being a jet engine mechanic, 2 & 1/2 yrs. as asst. crew chief, I decided to become a diesel mechanic on 18 wheelers. I worked for largest Ryder shop in state being Doraville, Ga. just north of Atlanta. Had tractor come in that would not hold road, tractor would turn to the right when holding steering wheel straight, you would have to turn wheel to the left as fast as you could to keep on road. Supervisor had top 4 mechanics try to find problem, to no avail. He had me stand on catwalk, just behind cab, while he drove down 2 lane roadway in front of shop, wanted me to look at rear suspension, axles, etc. With tractor back in shop I placed a large rubber scotch block in front of left front wheel, approximately 3 feet in front of wheel. I had a co-worker look at left front suspension spring, while I drove tractor hard & forward into rubber scotch block sternly, & sure enough bushing & solid steel pin inside of eye of left front spring were broken causing tractor to dart to the right. I'm a praying man & was asking for help from above. The driver of that tractor had to use a rental for approximately three weeks & was glad to have his old truck back.
