theoldwizard1
- Sep 9, 2012
- 16
- 48
Toro Super Recycler, 3 speed, w/Briggs & Stratton Quantum vertical shaft (128802-0615-01). My son's mower so I might not have all the pre-failure data exactly correct.
This mower has always been hard to hot start. About 10 days ago it was a no start. Checked for spark using a Lisle 50850 Ignition Spark Tester. Nothing.
About 5 days ago, I installed a new spark plug and Stens coil. Used a business card as a gauge for setting the coil gap. It started, but immediately begins to miss and puff white smoke. Eventually quit.
3 days ago I removed and disassembled the carb. Reamed all passages with a fine wire and sprayed with carb cleaner. It tried to start once but stalled.
2 days ago, I pulled the new plug. It was wet. I pulled the flywheel to check the key. It was fine.
I'm going to re-assemble tomorrow, but I am stumped.
