Toro ss5000 Back wheel locking up
Susette
I bought a used Toro ss5000, I have about 4.5 acres of grass....first time out had been cutting about 45 minutes the back left wheel will not respond checked the wheel release on the side to not avail. It is very hot and humid out toady. Could it just be too hot? Please pass along anything else I should look for and check. Thanks in advance
Sounds like Hydro pump or drive is having problems. Check oil level and bleed system.
