Toro recycler issue
nova87
Mower will start, run briefly and then stop. Tried loosening gas cap and replacing gas -- both to no avail -- any suggestions appreciated.:smile:
Parkmower
Clean the carb. YouTube has many videos showing how to do it.
Briana
WELCOME to LMF
I moved your thread to the Toro/Wheelhorse Forum. :smile:
Carefully remove the bolt on the bottom of the carb. Try to do so without removing the float bowl. This bolt is also your main jet. Clean it carefully, install. If this does not fix the problem you will have to pull the carb and rebuild it.
