I'm looking at the new Super Recyclers to replace my 1993 Toro variable-speed recycler. I've talked to one repair tech and two salesmen from different dealers. Which engine should I buy with the Super Recycler, the Toro or the Honda? Both are overhead valves, the Toro has 3 rings on the piston compared to the Honda's two, or so I've been told, and I'm cutting a 5000 square foot lawn. I'm a bit anxious to try the personal pace as I wasn't real happy when I tried them when they first came out, but hear they're much improved now. Lawn is somewhat rolling but nothing seriously steep.
If you're into model numbers, it's 20381 or 20382. Same body and tranny, only different engines. Thanks for your help!
