Toro/kohler mower throttle & choke issues
juntjoo
https://youtu.be/1hJbR_k48dI
I'm not sure how all this works but I think I might need a new spring or something. Can anyone enlighten me on what I'm looking at and maybe what the problem is. At least with the throttle as I think it I get that working I can at least use it. I'm thinking of tying it open with those gear ties twist ties. That way I can adjust. For now at least.
juntjoo
I bent the ends of that spring a bit and solved the problem. For now at least. I might have issues with that choke linkage. I'll find out next mow...
Scrubcadet10
Moderator
Staff member
Good luck! hope that solved it.:thumbsup:
