Our Toro model 74451 zero turn currently has 15.9 hours on it.  The service interval suggests changing the hydraulic system filters and fluid after the first 75 hours, so we are a bit away from this service yet.  After the initial 75 hour service, the recommended interval is every 500 hours when using Toro HYPR-OIL 500, or every 250 hours if using Mobile 1 15w50.  So, the Toro oil doubles the service interval by 250 hours!  Or so they claim!?!?
Our hydraulic reservoir is a bit low and we need to top it off so that it is right at the cold line when cold. Is it perfectly acceptable to add 15w50 to what I would assume would be the original Toro HYPR-OIL 500, since the machine was bought new from the local dealer? Or should we only add the Toro HYPR-OIL to top it off since the hydraulic system has never been drained?
Secondly, is using Mobil 1 15w50 a MUST or will any other brand's 15w50 oil suffice? The manual doesn't suggest using Mobile 1 FULL SYNTHETIC for 15w50. It only states "Mobil 1 15w50 fluid." I assume they are referring to regular motor oil, correct?
Thank you!
Thank you!
