Toro groundmaster 72
MarkinMN
I need help finding/ acquiring rebuild parts for toro continental R839 engine.... Gasket kit. Bearings . seals. Oil pump rebuild kit. Water pump.
Please post the model and serial numbers off the ID tag. This will help us see which parts you will need. With out them we are blowing in the breeze.
MarkinMN
30780 model 20304 serial
Looks like you have a unit that is about 35-36 years old. You won’t be able to get those parts through Toro, so I suggest you contact Continental Motors directly to see if any of those parts are still available. This site might help you. http://www.continentalengineparts.net/. If they can’t help I would get in touch with a fork lift repair service in your area. Those engine were use in many of the outdoor lifts. Sorry I can’t be of much more help.
