What happens when electric clutch is run off battery using a toggle switch
J jiwatson Member Joined Dec 21, 2017 Threads 4 Messages 16 Aug 5, 2019 / Toggle switch #1 What happens when electric clutch is run off battery using a toggle switch
NorthBama Well-Known Member Joined May 28, 2014 Threads 9 Messages 936 Aug 5, 2019 / Toggle switch #2 Its not safe to operate unless it operates with the safety switches connected
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 63 Messages 15,817 Aug 5, 2019 / Toggle switch #3 You now have an accident waiting to happen. It would probably be bad.
