Boobala
- Feb 15, 2015
- 200
- 7,000
WELCOME to LMF, We hope to help you with your lawn-equipment issues. In order for US to help YOU, it will save much time & frustration,IF you provide us some information about your machine, there are THOUSANDS of different machines out there, so asking about a GTX -xxx or LMYY-xxx is usually the SERIES of a machine, locate your ID plate/ sticker (locations vary so see your MFG'S website for location information,) (a great many are located under the seat, others are elsewhere,) your help on this, speeds up how we find the info. needed to help YOU ! It makes for a better experience for all concerned, IF your ID info is missing for some reason, then pictures are suggested, remember WE can't see what you can ! see example :
....click to enlarge
also, you might consider taking lots of pictures when you work on your machine, pics are a GREAT way to see / remember which way parts go-together, (ever remove the springs & linkages of a carburetor, or even the "deck-belts" ), they actually become your re-assembly manual, or help to "show" a part or area being discussed, ( a picture is worth a thousand words is true in a lot of cases here !! ) Hope you enjoy your visits here .........Boobala
