Timecutter ss 4235 leaking oil back bottom of engine
ddeconza
  • / Timecutter ss 4235 leaking oil back bottom of engine
Timecutter ss4235 leading oil rear of engine bottom center... help!
Thank for a second, you are posting on a forum which has service tech who are willing to help, but have no ESP or eye’s strong enough to see what you are dealing with. Help us help you??? Post units model and serial numbers. Post all engine numbers. We need to know exactly what you have before trying to make guesses as to the cause of your problem. Second, completely clean the area and surrounding areas where you think the oil is leaking. Run the unit until the oil shows up and snap a couple of pictures so we can have a better idea of what you are talking about. Resize the pictures and post them with all info requested. At that point we can provide you with ideas as to the cause.
Which of the nine models and of course the engine make and spec numbers will different each one.
