Export thread
Tiger Cub Dies When Not on Seat
#1
S
stick64
I have just recently started experiencing a problem with my Tiger Cub STC48A FH641V-BS09 where if I climb off the seat while brake is on and steering arms are in neutral, the engine dies. This is only happening after using the TC for a few minutes. When I initially start and move out of garage I can get off the seat and it will continue to run. I have switched out the safety seat switch with a new one. This did not help. Any thoughts ? thanks
#2
G
GMoore
I would lean more towards the other safety switches. There will be one on the brake lever and also on the neutral levers. A muti-meter set to check continuity will tell you if they are operating. They tend to be push button styles so the may also be gunked up and not moving freely,
#3
S
stick64
Thx for the reply. All safety switches Ohm out fine. It only happens after using machine for a while. Functions properly when I first start it up and get off seat with break and neutral levers in proper position.
