Frank nKansas
- Sep 8, 2025
- 1
- 4
My Honda Mower: Harmony II HRT216 SDA, MZCG 6092719. Manual Choke.
With the throttle cable disconnected such that the inner wire can move freely, and even though there is still 3/4" of the wire exposed at the far end, the throttle lever does not rotate down passed maybe 30 degrees from its full down position.
I took the throttle lever assembly off of the mower, thinking I would take it apart to see what seems to be blocking the movement, but it doesn't seem to easily open up. And I don't want to break it. I've seen a couple of pictures and videos that briefly indicate the lever should be able to rotate down much further. And the user's manual shows a diagram of it in the 'choke' position, where it is almost all the way down. Mine seems to stop at the "Fast" position... perhaps a little further than that.
I've adjusted the cable clamp at the engine end to allow the choke to work, but, the throttle lever movement just doesn't seem right.
Has anyone else experienced this situation?
Thanks.
Thanks.
