Thhis is why we run Tiger Cat Scags
jekjr
Two week intervals. Temp in the high 70's and 80's at night. Rain most days in the afternoon.
This is when it gets real in Lower Alabama.
Luffydog
Streaking like you have a slightly bent blade or bearings out in spindle or belt slipping if your looking at the pic you posted be on the left side of the pic.
7394
That's some deep cutting.
jekjr
It is streaking because it is cutting grass that is over knee deep and really really thick. It is cutting that mess in one pass.
It is getting that effect because it has no where for the trimmings to go and on a velocity deck that is saying a mount full.
We used to run Kubota mowers before we went to Scags. It would have taken 4 passes to get that mess cut down that slick. The blades were fine. They were not bent.
The other lines you are seeing is because of rough ground.
primerbulb120
I could use one if they made them in 44" size...
mcdonell
Impressive cut in that photo. I showed the photo to my wife who helps me mow with our Cheetah. Her response was they need to mow that grass more often. :)
Customer ought to be very pleased.
