soulvoid86
- Jun 12, 2015
- 1
- 5
Hello all,
New member here, and I'm not 100% sure if this thread should be posted here, so please feel free to move it if it's not correct. First time owning my own mower as well, hahah, but I'm a experienced backyard mechanic, and work on my own cars all the time. So I have a good mechanical knowledge/background, but I've never worked with a mower directly before.
So long story short, I bought a Snapper push mower (Don't have the exact model number on hand, at work right now.) for $20 out of our local news paper, knowing it was not running correctly, from an older lady who's husband passed away. She though it was an issue with the wiring. Got it home, and found out it had the self-propel feature, but was removed because it was broken. There were a few extra wires just hanging, so I snipped those off.
When I first got it, it ran Ok but ran at pretty low speed, even with the throttle handle cranked all the way up. It would then stall out slowly, as if it were out of gas. So first thing I did was pull apart the carb, cleaned it out good with carb cleaner and some compressed air. Changed the oil and spark plug, and also inspected the coil and wire (All's good there). Emptied out the fuel tank, cleaned it, and put a new fuel line on it (without a shutoff, until I get it running right). Started up great on the first pull, and ran for about 10 mins, then slowly died off again.
Next day, I pulled the carb apart again, cleaned it, and got it all back together. Ran great for about 15 minutes, then started doing the same thing. Then it would not start back up. It would fire 1 or 2 cycles, then stall out or not even fire at all.
So I stopped working on it for a few days, and it was stored on our enclosed back porch. I pulled it out a few days later, primed it 3 times, and it fired right up first try.. I pushed it forward 3ft, and it stalled out. Started it back up, and did the same thing. Now, when I can get it to stay running, if I move it in any direction, or pick the front end up as if I were turning around while mowing, it stalls out everytime.
I'm also not sure if the throttle cables are connected correct either. When I pull the throttle back to the STOP position, it just idles, it doesn't choke it out. And when changing the throttle position, it doesn't really do much other than putting it in either idle or full throttle, there's no in between. There's also a small metal clip hanging, and I'm not sure what it connects to exactly.
Below is a link to an external site that I uploaded all of the pictures that I currently have of the mower. If you need any more, or any more information, please let me know.
Photos: Snapper Mower - Album on Imgur
Thank you very much!
