Tecumseh peerless transmission
parafield
Hi! I'm looking for shaft keys for the transmission if anybody got any i would like to buy them 4 or maybe 2.
parafield
Oh and the patent no. is: 4.966.574
peerless model number should be on the side stamped on a metal tag sitting in a slot and held in by the top half
parafield
Thats the problem the tag must fall off or something. So i dont have it :/
Post the units model and serial numbers and we should be able to help you more. Do you mean shaft keys or shift keys? Big difference.
If you have the equipment the transaxle came out of the model from it might help finding out which 5 speed with reverse Peerless it is from the early 90's.
I mean the tractor numbers, not transmission.
Fish
Or a pic of it would help.
grumpyunk
I think the numbers are stamped into the case. If you look up from behind the seat area, on the rearmost surface, you will find the model number. You may have to scrub a bit to see them.
tom
