- Sep 24, 2017
- 277
- 6,740
Pulled this off an o l d go kart.
figured i'd get it running, and kind of "beautify" it.
99% sure no spark, sprayed carb cleaner down the plug hole, no fire. It has points and condenser ( I have never worked on one with that system), compression felt good when i pulled the rope, it may not be perfect but feels like any other small engine.
Any advice anyone can give will be helpful. I took out the plug, and the valve operation looks good. got about 10 pounds of mud dobber nest out from behind the flywheel too. Im sure that is the info tag screwed on the side.
