Hello everyone here, I'm new here
I own 2 Tecumseh BVS153 engines (Gutbrod lawnmowers), one which is totally normal, one with ignition key and "pulling help". They are probally very very very old, and, still they're running great. The are no problems, unless the problem with blue smoke. Both of them has the same problem, but the "normal" one has more smoke, and after 1 or 2 mowings, the spark plug gets oiled too much and can't run properly, the other one smokes less, and the spark plug doesn't get dirty at all. Both of them loose oil after mowing, so it is frustrating when you know you can always run out of oil, and destroy the engine, so you have always to check oil capacity (usually gets almost empty after 2 hours of mowing). So, if the lawnmoswers get into bigger grass, they smoke a lot more, and if you push the gas to the choke, it also smokes very heavy. There are no perfomance problems, just loosing oil is annoying. I also have a normal sized B&S engine, which works completely normal (no such problems). The two Tecumsehs have a small pipe next to the muffler which usually puffs somekind of white smoke, anytime, and also it is very oil. Is all of this normal? Or because they're simply old (older system) or just their age destroys them..? Is there a fix for it?
- Oil is filled up normal, not over max, not under minimum.
- It is stored normally, not staying with spark plug showing to the floor
- Air filter (sponge) is totally clean, no oil traces
- Carburetor is 100% is clean from oil
- While cleaning, it is leaned on the side as it shows on the sign
- They're 100% clean, and also maintained after every mowing
Thanks everyone in advance, and I hope I found my right LawnMower forum
