I know I have seen the chart on this forum.
Can you direct me to it again please.
LB
Find the date-of-manufacture code, usually found near the abbreviation "D.O.M." or at the end of the engine model number. The code begins with five numbers (or four, if the engine was made before 2004) followed by one or two letters. There may be more numbers after the letters, but the first four or five numbers will tell you when the engine was built.
Sponsored Links
Free Electronic Signature
Sign Documents Anywhere Instantly! Try It Free Right Now
DocuSign eSignature | Sign Documents Online
Use the first one or two numbers to estimate the year of the engine. If there are four numbers, the engine was built before 2004 and the first digit is the last digit of the year. For example, 2 means the engine was built in 1982, 1992 or any year before 2004 that ends in two. You must estimate the decade. If there are five numbers, the engine was built in or after 2004 and the first two digits are the last two digits of the year, for example 05 for 2005.
4
Use the final three digits to calculate the day of manufacture, since they indicate the day, starting at 001 for January 1 and counting up to the end of the year. Begin adding the number of days in each month, 31 for January, 28 or 29 for February, 31 for March, and so on, until you reach a total just below the three-digit number. The last month you added is the month of manufacture and the remainder is the day of the month. 032 means February 1. 060 means March 1 unless it's a leap year, in which case 060 means February 29.
Sponsored Links
Read more:
How to Find the Year a Tecumseh Engine Was Built | eHow
