Repairs SX75 clutch helpI need to repair
dukerocks
I need to repair the clutch on my JD SX75 and don't know where to start. I push the clutch in to slow down and then it just pushes in freely to the deck and will not gain back any speed. It will self correct for awhile if I put the shift into reverse but then again it will repeat the problem. What do I look at and what do I need to do to repair. Thanks
JoeM(GA)
sounds like you have a pulley arm sticking, or you've lost a spring. All the clutch does is move the tensioner pulley off the belt, I bet it's sticking for a moment. With mower off, look under the back with a mirror and light while someone else works the pedal, you'll find it pretty quick
