What are your alls thoughts on which sulky is the best on the market?
I have never used a sulky so I do not know which ones "are the best", but I can show you the different kinds and tell you what I think would be good/bad about them. Here are some of the kinds:
This sulky only has one wheel, and you put your feet on either side of it. The negative about this is it would leave a line in the middle of the cut grass.
This kind of sulky has 2 wheels. Depending on the width of the mower, sometimes the wheels are behind the mower wheels, so there are no extra tracks from the sulky wheels.
This kind has a seat. Again, the tires can be behind the mower tires so there might not be another track from the sulky wheels. But this might make the mower hardr to control since you are sitting down.
This kind has NO wheels. It just slides around on the ground. It is supposed to be good because it keeps you at the same height off the ground whether you are "sliding" or walking. You can see it here:
Proslide.
