Stumped - Poulan Pro Snow Blower
bk10s
Hello All - A friend moved south and gave me this beautiful, hardly used unit. It has never run quite right. The rpm would surge up and down and it would only run on choke. I removed carb and cleaned everything. Still the same thing. I replaced with a new carb, plug, and fuel line. It runs better with less surging, but still on 3/4 choke. Is there anything I can do?
We are going to need the engine model number information so we can see what you are looking at.
bk10s
Poulan Pro 624 ES 961920037-00
Engine is LCT 208
Okay need the engine numbers.
Going to a long number like PW4HK18650178EABGIOQUVX5E1M or similar Alpha-numeric seq. in order to look-up the right carb.
Looks like LCT 03122 for the carb part number
bk10s
Thank you - Yes - That is the replacement I used. Still will only run good on 3/4 choke. No surging anymore.
IL your eyes are better than mine as it took a lot longer to translate that dot matrix number set.
PW2HK18650178EABGIOQUVX5E1M​
barny57
After you replaced carb, did you reset govener?
bk10s
Reset the governor.....Never heard of that! How do I do it? There is no more surging, but it will still only run right on 3/4 choke.
