I am not an engineer or anything but I think the cylinder length is something you will have to determine on the machine, you are talking 135 +- degrees of movement and it depends on the attachment points on the bar and mount. I'm not sure if you will be able to get a cylinder that will be able to move the bar that much with out binding up.
Tom
