String Trimmer
volt
Stihl fs 45 String Trimmer starts and Idles fine but when I pull the Trigger it accelerates then slows down.
Changed Fuel Filter, Sparkplug, Fuel, Adjusted Carb.
Nothing helped, would appreciate any suggestions.
Volt
The carburetor needs rebuilt. Unfortunately the Zama repair kits are only available from Stihl per Zama and if your Stihl dealers are like the ones around here they can't or won't order the kits instead insisting on you ordering a replacement carburetor.
dawgn86
Volt
My FS-40 did this...couple of the fuel lines were split due to age...for $50 i got a new carb..fuel lines..tank vent and filter from Sawzilla and runs like new.
Tiger Small Engine
Remove Zama carburetor, take apart, clean, replace metering diaphragm, install. I have a 90-95% success rate after doing this with two stroke carburetors.
