wilburn cox
- Feb 24, 2014
- 107
Like I said earlier, you either have excess fluid hydro-locking the piston, or something has changed the ratio in some way, like excess carbon, different stroke or different piston, or closer fit of the cylinder to crankcase that would change the ratio. there were many models that were real close to this one, maybe you have a slightly different crank/piston, etc...
Check out those threads I sent you in the p.m., there are some serious poulan nuts there that could probably help, they love those old Poulans.
Thanks again Fish. There are no fluids in the saw at this time, has been dry for several days. No carbon anywhere. Piston & cylinder were replaced with a used set ordered from "Chain Sawyr". Piston and cylinder were a match for the original from the saw. Motoman answered earlier today and said some of the old saws had transfer ports cast in the crankcase and they might be blocked. I have no idea what transfer ports are. Are they tiny holes such as carb. passages?? I will check this out as I have some more time.
I appreciate the 2 forums you mentioned and I did register for the "SawHawgz.com. I have not yet posted my situation on their forum but will shortly.
Appreciate all of your suggestions.
