Ric
- May 7, 2010
- 139
- 5,765
No luck. I cleaned and dried the spark plug and cleaned the spark arrester screen. It won't even turn over. Nothing. I almost grabbed it and smacked it against a tree! I'll just go to the dealer on Monday.
Have you checked to see if you have any fire or spark at the plug? put your plug wire on your plug and with a pair of insulated pliers hold the plug against the top engine where you would normally screw the plug in, crank the engine and watch to see if there's any spark in the plug.
