Stihl FS 45 throttle trigger spring allembly
Monty57
Stihl FS 45 throttle trigger spring assembly
Hi, I had a stuck throttle trigger and pull apart the trigger assembly to find the problem. I'm trying to put the throttle and trigger back together and have a loose spring at the throttle trigger. I hope someone may have a photo or description of how the spring and trigger is located. Should be an easy fix then, just fiddly. :smiley_aafz:
