Stihl BG 85 z Stihl blower. Primer bulb issue?
craigtrader
My stihl runs if i prime it through the plug. I cant get the primer bulb to fill. It has new plug clean high octane gas and is stored inside.
When I can get it running it runs good. the primer bulb was replaced + put in by a shop and he was unable to get it to prime or get the primer bulb to fill. Should the carburetor be replaced? I'm some what handy and could probably do that. Im really looking forward to some constructive input. It has spark and all that's needed to run. I'm thinking the main issue is the primer bulb. Im guessing something is probably plugged not allowing proper airflow to the primer bulb.
craigtrader
Herea the model number
Before you start replacing parts I would be checking to see if the fuel pickup line is in good condition. If the unit is more than 3 years old and been store during the off season with fuel in it, good possibility that it is broken or cracked.
Replace the carburetor. The primer base has failed. Due to cost it is just a cheap to replace the whole carburetor.
I replaced several Stihl carburetor because of these primer bases failing.
craigtrader
Sorry I forgot to include fuel line was replaced.
craigtrader
Hi I replaced the carb and it started right up. Thank you
