Sticky hamburgers
PTmowerMech
This method will make your burgers so sticky, there's no chance they'll ever break apart. In fact, if you accidently get some on your hands, it's kind of hard to get off.
Anyone who prepares their own hamburger patties, know that sometimes they don't always stick together when you're cooking them.
So I developed a 100% way to make them extra sticky before cooking them.
First I'll take two eggs and whisk them for a minute or two in a bowl. Whisking the eggs first seems to work better. Then pour that into my mixing bowl. Then add the seasonings I want. Then put 2lbs of hamburger meat into the mixer and mix on low for a minute. Then increase the speed in increments until it's on high for another minute or so. You'll see how the meat is sticking to the sides and not falling back into the mix.
I usually cook burgers on a cast iron skillet. So I'll use a wooden spoon to roll some meat into a ball, while it's still in the mixing bowl. Then put that ball into a hot skillet and shape it round. Then take the spatula and press it down as thick as I like it. Then just repeat this until all the meat is in the skillet.
I also use one of those rubber flexible utensils to scrap the edge of the bowl, so there's a LOT less clean up.
On a side note: When you're done, put some soapy water into the mixing bowl, along with they other dishes or utensils that got dirty. Clean up is a snap. Especially since you didn't have to touch the burger meat with your hands.
The mixer:
The rubber utensil:
Auto Doc's
The mixer:
The rubber utensil:
Hello PTmowerMech,
Sunday, Labor Day Weekend.
Where do you insert the compression tester? LOL
Just kidding. In a bowl I use 1 egg per pound of hamburger, a light shake of breadcrumbs, season with a little salt pepper and garlic powder, mix by hand wearing food prep gloves. I shape them with a burger press and wax paper.
Chill the in the fridge for about 30 minutes while I clean up and get the "old faithful" cast iron pan hot with a little bit of olive oil.
From there seer them on each side and final cook them on medium low until the instant read thermometer says 165F (or better) internal temperature.
Anything below 165F+ is inviting stomach or bowel issues later. E. coli sickness is never a good thing. Any chopped meat has to be fully cooked.
I refuse to eat a crunchy "smash" burger.
PTmowerMech
Hello PTmowerMech,
That's almost identical to the way I use to make them. I've just found this new method of whisking first, then mixing everything in the mixer, makes the patties stick like glue. It doesn't miss a spot of meat.
I usually stick the skillet out on the porch for the night. The critters do 95% of the clean up. lol Then a little soapy water, to clean it thoroughly, some bacon grease heated on the burner and it's good as new.
I've never used a thermometer. I heard that's all the rage now.
Auto Doc's
I only recently adapted to using and instant read thermometer in the past year when I cook any ground meat. Looking like it is done and knowing it is done are totally different things. Also, overcooking can make a burger really tough and dry.
What many never think about is a cut steak versus chopped steak (hamburger).
A whole cut steak such as a ribeye is quite sterile on the inside while the chopped steak has been cut/ground into small nibbles by grinding and extrusion and it has had a lot of exposure to open air, the temperature, and the tools being used. Anywhere along the way if anything is not sterile, e coli will quickly develop.
Anyone who orders a rare hamburger is inviting trouble.
RayMcD
I don't know about the burger being sticky but I drop 1 egg and 1/2 cup of plain bread crumbs in a 1 to 1 1/2 lb ground beef just make them very good, try it you'll never go back to plain ground beef, Ray
