Stens 2c fuel lines.
PTmowerMech
I happened on a box of Stens 2c fuel lines (115-512 True Blue) that I know can't be much more than 2yrs old. Probably 1 yr, now that I think about it. They've been under something else, so I didn't see them.
None the less, I opened the box and they're hard already.
I'm pretty sure they were soft when I got them. Seems they'd have lasted a lot longer than that.
If they were stored in a dry environment it would not surprise me if they dried out. Humidity is a friend of fuel lines.
Don't trust the false advertisement that they are 100% ethanol resistant and that they do not shrink. I did a month test on them they they both harden and shrunk while fully submerged. These were brand new lines at the time so I simply tossed them and went back to using Tygon F-4040 and Echo rubber lines.
Rivets:
If they were stored in a dry environment it would not surprise me if they dried out. Humidity is a friend of fuel line.
My test was with new lines fully submerged in fuel mix so there was no humidity involved.
PTmowerMech
What sizes are the most common? 3/32" ID 3/16" & what?
Hammermechanicman
Welcome to the world of "what size is that damn fuel line" I have 50' boxes of a few sizes of Tygon, boxes of both sizes of Echo line, some of the Honda stuff, spools of 1/4" and 5/16" and 10' strands of other Tygon sizes and I still find hand helds that are something I don't have and I have seen things use 3 different sizes of fuel line WTF!.
Good luck.
PTmowerMech
Good luck.
My problem is I never bothered reading the sizes after I buy them. And when I go to install new ones, I just match the old with the new and carry on.
That one of the common lines. .080 id x .140 od is another one. And do see some .117 id x .211 od; not as much as I used to. Then there is the 3mm id x 5mm (ECHO 90014) and 3mm id x 6mm (ECHO 90015) rubber lines.
