Tom old Murray
- Nov 10, 2017
- 1
- 10
Boobala,
I thank you for YOUR patience, understanding and willingness to help and I am very grateful.
I’ll try to go over sometime this morning and get started on the steps you outlined, pretty sure I follow/understand what to do.
Not trying to question your thinking, but maybe you can explain where I went wrong in mine. Last evening I had 12.5 volts at every stage, battery, solenoid battery post, solenoid trigger post, solenoid output post and at starter post and the starter didn’t turn. To my understanding from the material you have sent me, that circuit being completed should indicate the switch was working correctly— having voltage at the starter should have made it turn, what am I missing here? Also, after I get through the steps you outlined, if it still doesn’t crank/turn over should I wait before putting gas into the intake?
A couple of your suggestions I should have thought about, the known good battery because I don’t know if there was enough amps available to turn the starter, hand spinning the engine and of course bench testing the starter.
Thanks again for your help and I’ll get back with you later.
Tom
Tom
