Hi all, this unit has only been used twice since new. A mate has dropped it over for me to try and crack it. Problem being it won't start, or even give a cough or fire at all. After checking the usual things with a small 4 stroke, such as does it have spark/ fuel / compression etc? which it has all of those things, yet won't even fire once with a squirt of aerostart down the plug hole, and a little on the plug tip. I would have thought that with all of the above, it should at least show some sign of life. Any ideas on this one would be great, as it has me totally done at the moment. The machine still appears new, not a dirt spot on it.
