So I just recently bought a Husqvarna RZ4222F and I have about 25 hours on it now. Love it but when I turn the blades on it squeaks each time really quick. Is this something I should worry about and is there anything I can do to stop it.
If it happens when you engage the blades it's probably the belt on the PTO. It's common and probably not a whole lot to worry about or that you can do. You may want to check your the tension spring on the pulleys and check the belt and make sure there are no worn spots on the belt.
