Spring 732-0638 1998 Mtd Yard Machine. Spring connected to transmission support bracket came off. Don't know where it goes in the front.
Bozo55
  • / Spring 732-0638 1998 Mtd Yard Machine. Spring connected to transmission support bracket came off. Don't know where it goes in the front.
There's a vertical metal post it goes on for one end. That is a stout spring. You will need a metal hook to assist in installing it. Be careful. Other end goes around the pulley plate.
