I have a Vanguard 36hp on a ferris mower. I am having trouble getting it to idle and getting high idle set. I did a static governor adjustment
and am trying to set the idle speed. When I start it it will idle for a while and then start speeding up and will finally settle at 2800 to 3000
rpm. The throttle plate seems to be opening up as I can push the throttle arm back to the idle screw and it will go back to idle speed.
If I let go of the arm it will speed up again. I do not see a idle return spring on the linkage. Any ideas as to what the problem is
or what I might be missing?
