I purchased this pressure washer new back in 1991 and would like to find a manual for it. It has a Briggs and Stratton engine and a Cat brand pump. There is a metal tag on the frame stamped "11558", and I don't know if it's the model or serial number. It never had a nameplate or sticker on it that identified the manufacturer. Google leads me to believe it might be an Ex-Cell or Excell based on the wheel frame, but not sure. Briggs and Stratton makes pressure washers but their model number is not on the frame and don't know if they made them back in 1990.
It's looking its age but still starts on one pull and runs perfect. I've had to install a threaded insert into the spark plug hole and replace the carb diaphragm, but no other work aside from changing oil and cleaning air filter.
I believe it's 1250 PSI (with a very high GPM), and think I purchased it from Sam's Club.
Does anyone know what brand/model this is?
THANK YOU!
Frame tag: "11558"
Cat Pump model: 2SFX30G
Briggs and Stratton 5 HP cast iron engine model: 132232-4036-02
B&S Engine Model Series: 130000
Code: 90111607 (Manufactured Nov. 16, 1990 at plant #7)
THANK YOU!
Frame tag: "11558"
