Snapper Rear Engine Ride on Deck Adjustment Problem
Smokeeater
I have a Snapper model 7800932-00 and it says in the manual to adjust the deck height for left-right put something on the rear centre of the deck to support weight and if it needs to be adjusted slowly turn the Eccentric on the Left Front until blade tips are at same height.
I found the "Eccentric" and it's not budging. I even had vice grips on the nut and nothing. I don't want to wreck anything.
Am I doing something wrong?
S
That was the way it worked for me.
That said...
Bumping for more knowledgeable people.
Hope someone here can help you.
